I
I am bonkers
In another thread doitmyself gave me helpful advice on how to check the wiring on my faulty Tower 2 port valve. All feeds seem fine but the valve doesn't fully close and it doesn't always switch the pump and boiler on. Doitmyself suggested taking the actuator off and checking that the valve spindle turns easily.
I've removed the actuator motor (which turns on and off OK via the thermostat) but I can't see a spindle. Do I remove the 3 bolts holding in postion the plate which I can now see, or will it all fall apart?
I suspect that the spindle isn't turning far enough one way to fully close the valve and not far enough the other way to close the microswitch contacts.
Any advice much appreciated.
