View the thread, titled "faulty ferroli modena 102" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
cossie362
Hi peeps
strange fault with the above boiler tryed the helpline but they are as good as usless
boiler was working fine had a leak and the pcb board got fryed.
had the board changed now the boiler when calling for dhw starts up can here the fan running
boiler sparks but no gas coming out of the top of the gas valve to fire up the boiler gas valve is also new
also have checked electrics goin to the valve all okay any help or ideas much appreciated.
Do you hear the air pressure switch click.?
I would replace the boiler with one not from B&Q.
The old modena's were decent boilers and easy fixed. Get someone in who knows what they are doing.
Btw it is not the pressure switch before you waste money on one of those.
As per tamz. The Modena is only decent boiler Ferroli made.
Get it looked at.
I just said can you hear a click as they go in sequence. Didn't say it was the air pressure switch.
Reply to the thread, titled "faulty ferroli modena 102" which is posted in UK Plumbers Forums on Electricians Forums.
