View the thread, titled "Faulty Watermill power shower, need help with adapting pipework" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
R
realitybites
Hi, have a watermill osprey 2 powershower (not low voltage) that apparently isn't made anymore. Had a faulty one first time round but was able to replace the whole thing so no real plumbing involved. I am now faced with a problem, the pipework (hot and cold) enter from the top left hand side which I think is a little different to most other all in one showers. I want to fit a triton as a replacement but the pipework is in the wrong position. Could I use a combination of elbow joints plastic and compression joints to adapt it and would it be difficult.
No u cant and Yes it will be.
Call a plumber when it comes to showers and when ur qualified replace it with a aqualisa hmmmmmm.
And going by your posts you seem to have fitted a bathroom and other "plumber only" jobs, a bit hypocritical don't you think 🙂
On the shower side of things can anyone recommend a suitable replacement. Going by hiretools recommendationI was looking at this
Aqualisa Aquastream Thermostatic Power Shower Satin Chrome - Aqualisa available at Plumbworld
Might make things a bit easier due to the various entry points and the fact that I could leave the pipework exposed if push came to shove.
Reply to the thread, titled "Faulty Watermill power shower, need help with adapting pipework" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
