moogwai
Evenin lads just went to the above pile of poop which on the display is constantly calling for hot water. I isolated the cold water going into the boiler and the fault remained on. Fan was running but the boiler didnt ignite.....just wondering what it could be....any ideas apart from axing it?? Cheers.
Sounds like a sticking flow sensor ... Can't say I've ever worked on one mind... How is the hot water flow detected, hall effect turbine, diaphragm pressure switch?
had a similar problem with a potterton turned out to be the pcb, but the boiler practically destroyed itself when it kept overheating, needed new av, prv etc
youre right about ferroli being c###
I was thinking it may be a flow sensor when i driving home. Thinking i will try that first but take a pcb with me. And its not the greatest installation ive seen.....had a struggle to get the casing off as its pushed right up against some pipework!!!
Thanks lads.🙂
