View the thread, titled "Ferroli 701 problems" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
MITCH125
I have recently had a new gas valve and fan fitted to my boiler. However i have noticed that it now works ok but after being on for a few minutes it only stays on for about 15 seconds. It then goes off for about ten and then comes back on. It does this throughout the programme. It seems to be working very hard and i'm sure it's not right
mitch125
maybe the gas pressures have not been set correctly when gas valve replaced,sounds like you have no low flame,or low flame setting set to high
IMHO
The flame is very high and after a couple of seconds it sounds like a kettle is starting to boil. I don't know if i've put that very well but it is as if it's too hot in there, if thats possible
should not do this on hot water mode if pump is faulty please clarify
Hello All.
I have just had the bolier in hot water mode, it stays alight whilst the hot tap is running giving me hot water. It does the same when it is in heating timed and hot water and also heating on and hot water. It's the heating that stays on for a few seconds then cuts out and then repeats this. This happens when its on timed heating and heating continuous. I know I will have to call out a plumber or central heating engineer if there is something in the chamber that needs fixing but is there anything I can look at as a DIY'er before I call them.
Reply to the thread, titled "Ferroli 701 problems" which is posted in UK Plumbers Forums on Plumbers Forums.
