View the thread, titled "Ferroli 77 ff water too hot" which is posted in Bathroom Advice on UK Plumbers Forums.
W
websternik
Hi there,
My Ferroli 77 ff combi boiler fires up fine, the heating works, it heats the water it's just that the water is scalding!
There is only a heating temp gauge which is currently turned down to almost zero...
Any ideas how I can get the water to not be so hot?!
Many thanks 🙂
check your mains stopcock is fully open, are you in a hard water area, if so you may have parts of the boiler blocked which need flushung out to let a higher flow of water through, call a gas safe technician to sort you out.
Reply to the thread, titled "Ferroli 77 ff water too hot" which is posted in Bathroom Advice on Plumbers Forums.
