W
waterpistol
hi there, i have encountered a problem with my combi boiler; basically i have no hot water and no heating. but, after replacing the air pressure switch (on a plumbers diagnosis) the problem persists. i noticed that when the boiler started to deteriorate there would be a clicking noise before the burners would fire up, then the length of time between the clicking starting and the burners firing up got longer till no more clicking and no more firing up. also when i came to relight the pilot light recently the ignition switch didn't work at all and i had to use a lighter to re-light it.
having examined the air inlet/outlet tube i notice there are no leaks or holes and when i suck on the tubing the air pressure switch clicks into operation and the burners fire up, so i am thinking it's the brain that's at fault not the air pressure switch but hoping it's not going to be too costly.
i also noticed that the upstairs taps, which are a metre from the boiler never had any trouble with being supplied with hot water but the downstairs kitchen taps were a lot less reliable...
ok, sorry to write an essay. cheers, ben.
