View the thread, titled "Ferroli boiler loosing pressure" which is posted in Boiler Advice Forum on UK Plumbers Forums.
H
Hotsauce19
Hi everyone after some help with my central heating problem
my ferroli F30 boiler has been off all summer only supplying DHW. Now that I have turned the heating on I am having to top it up at least once a day as the pressure in the system drops to 0
i started by looking for leaks or air locks. I have checked every single joint and radiator in the house. I've even had the floor boards up to check for leaks. There are NONE. I have added fernox leak sealer to the system and bled it thoroughly just to make sure. If I leave the central heating off for a 24hr period the pressure maintains.
Once the heating is on the pressure drops to 0 every day
i have isolated the central heating supply and return at the boiler and the boiler maintains pressure
i have checked the expansion vessel and no water coming out ov the valve however the pressure in the expansion vessel was a little low so I have recharged it to 1bar this has slowed down the pressure dropping in the system but I still need to top it up daily
when the central heating comes on the pressure in the system rapidly increases from 1.2bar to over 3bar and once the heating goes off it drops to bellow 1 bar
anyone have any ideas what the problem could be or what to do next as I'm at my whits end 🙁
Stop touching your boiler. If your not gas safe registered you could be putting your self and your family in danger. Get a gsr engineer in to look at it!
1) it would of saved you a lot of time.
2) it will probably save you money as next you will start replacing bits here and there costing you a fortune.
A decent engineer should sort this within an hour.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. http://www.ukplumbersforums.co.uk/im...-gas-engineer/
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competetence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
[DLMURL="http://www.co-gassafety.co.uk/deaths.html"]CO Gas Safety[/DLMURL]
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "Ferroli boiler loosing pressure" which is posted in Boiler Advice Forum on Plumbers Forums.
