paingiver
Hi
Wonder if you could help with CH problem. DHW is working fine with my Ferroli F24 and the BAR tends to hover between 1 and 1.5 went using DHW.
However, when I switch the CH on, the boiler fires up for a few minutes, then the BAR creeps to around 2.5 BAR and then the CH cuts out. I think it might be something to do with the pressure vessel? Do I need to check whether that needs pumping up to 1 BAR? If it is already at 1 BAR what else might be wrong?
Thanks in advance.
Thanks in advance.
