View the thread, titled "Ferroli help needed in Malvern, Worcs" which is posted in UK Plumbers Forums on UK Plumbers Forums.
desperateinmalv
Hi, I was recommended to post something here re. our broken boiler - original post as follows. Please reply if you can help!
Hi, we have a Ferroli F30 that hasn't been working for either CH or HW for a while.
The low water pressure light is flashing despite the pressure gauge reading 1 bar. Having spoken to Ferroli I 'overrode' the low water pressure sensor by just joining the leads to it with a piece of wire and it worked fine, so I changed the water pressure sensor itself but that hasn't solved the issue. If anyone has any suggestions as to what else I can do I'd be very appreciative! Could changing the pressure gauge itself fix it? It seems to work fine as it rises/falls as I fill/bleed the system. Someone has mentioned that the flow and return valves could be jammed but I'm not sure what this means?
Many thanks in advance
Robert
thank you for your enquiry Robert if anyone can sort out robs boiler issues please contact him via pm
Reply to the thread, titled "Ferroli help needed in Malvern, Worcs" which is posted in UK Plumbers Forums on Electricians Forums.
