View the thread, titled "Ferroli Modena 102" which is posted in UK Plumbers Forums on UK Plumbers Forums.
ptho8ap
Hi Guys, newbie here to the forum, found this site whilst trying to figure out a problem with the above boiler!!! right found the boiler fan working but not firing, removed the cover and away she fired, put cover back on and it cut out again!! I have replaced the venture, pipes, APS, flue restritor removed as flue is 2m long, also no blockages in the flue and now fitted a new fan as directed to technical support... but I still have the same problem. does anyone on here have any experience with this boiler as to where I can look next, customer says boiler was cycling for about 2months before it stopped altogether. Any help would be appreciated. Thanks Paul (GSR No 506957)
You need to speak to a mod as we can't answer tech questions on the open forum. Get it moved to gas safe only. search and you find out how to access it.
Reply to the thread, titled "Ferroli Modena 102" which is posted in UK Plumbers Forums on Electricians Forums.
