F
Fabby19
Hi, I have a ferroli modena 80e which has started to play up. It was not igniting with the hot water or central heating so called in a plumber. He serviced the bolier and couldnt find anything wrong with it. It springs into action when the front casing is off or hanging down which is strange so he recommended a new pcb. When he tested the fan, the venturi crumbled(which seems quite common) which we also replaced. So now we have a new pcb and venturi and still have the same problem. The boiler either works for a while then shows the lock down light or the green led light comes on but has not ignited. Plumber now avoiding us and cant get anyone else out. Can anyone help. Fan seems ok, air pressure switch too.
