View the thread, titled "Ferroli Optimax HE 38 C - variable hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
C
CraigC
Hi All
I have a problem with my Optimax HE 38 C boiler. Basically the hot water temperature starts off hot then quite quickly becomes tepid at other times the water is very hot (scalding). Have tried switching between ECO and comfort settings but makes no real difference.
Seems very erratic. Central Heating temperature is fine?
My question is does anyone have any ideas what might be causing this?
Like a lot of other people we had a lot of problems with our boiler when first installed in 2008 - had Ferroli out many times - one of which was poor hot water - the engineer repaired/replaced some parts at the time but has been ok since then.
We have quite acidic water which probably does not help.
Does anyone have any thoughts on what may be causing the erratic hot water temperature but not central heating?
Thanks in advance for any help
Craig
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location - [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - http://www.ukplumbersforums.co.uk/users/8668/ or Redsaw - http://www.ukplumbersforums.co.uk/users/2718/ who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/ce...ed-advice.html (notice gas safety related advice)
Reply to the thread, titled "Ferroli Optimax HE 38 C - variable hot water" which is posted in Bathroom Advice on Plumbers Forums.
