ferrolli 77 ff manual wanted
View the thread, titled "ferrolli 77 ff manual wanted" which is posted in UK Plumbers Forums on UK Plumbers Forums.
plumbdocter72
hi looking for a pdf manual for ferroli 77 ff combi boiler age 1991.
boiler pilot light on fan ok air no hot water or heating what could it be?
[DLMURL]http://www.aroundtownflats.com/manuals/Boilers/Ferroli/other%20ferroli%20manuals/SPARES_77FF%20POPULAR.pdf[/DLMURL]
Thanks for the help; information, do you have a service manual so that i can do the fault finding checks in pdf as well kind regards
hi no hot water or heating the fan is running the pump is running air pressure switch ok does not fire up on main burner, if you have service manual i can test the appliance have the equipment for the job & gas card thanks.
Hi plumbdoctor72, I had a callout to same boiler, the problem was a slight blockage in the pitot tube (supplies air to the air pressure switch). A quick blow down it (via the rubber hose borrowed from my manometer) and all was well instantly.
Worth a try -its free!
thanks very much!! this should help solve the problem will have a look test the boiler on weekend
i have the manual for this, pm me your email if you still need it
Would you please send me the PDF of the manual for the ferrolli 77 combi? I'm having a problem with the heat sensor I think and I want to do the fault finding paths. Previous owners have left no manuals!
Not a part of the boiler you should be touching!
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "ferrolli 77 ff manual wanted" which is posted in UK Plumbers Forums on Plumbers Forums.
plumbdocter72,
Dotty,
