P pjgas Plumbers Arms member Plumber Gas Engineer Apr 15, 2014 #3 E.s.p I was going to say between the three pubs on this boiler witch one would be the culprit. Fan running pump running no ignition no fault code
N Nostrum Plumbers Arms member Plumber Gas Engineer Apr 15, 2014 #4 Actually I was just taking the p!ss as your post was so vague there was no way anyone could have helped you! Check the air pressure switch
N Nostrum Plumbers Arms member Plumber Gas Engineer Apr 15, 2014 #7 Is it going to lock out or just fan running continuously ?
