A
alexp78
I only had some 3/4 inch rubber washers to replace the indented fibre washers in leaking basin tap flexi connectors. Is there a problem with this or should fibre washers be used?
i have recently had a few problems with fibre washers ie not the exact correct size 🙁 I generally put them in my mouth prior to fitting dont know if that has got anything to do with it.
Im worried about the trail of leaking loos behind him all missing their doughnuts lolTimes must be hard if you're eating your washers(or is it the missus,can't cook won't cook).
Do you have 1/2" for elevenses and 3/4" for lunch
LOL
LOL the wifes a good cook, what I meant was I put them in my mouth prior to putting them in place to make them swell up. LOL 😉
whats the difference between an erect ***** and a bonus ??i employ my missus for that winston..😉
Well there's no leak. One on hot tap the other on mains pressure cold. I put two in each side as they were thinner than the fibre ones coming out.
So no-one reckons that rubber is bad?
Reply to the thread, titled "fibre versus rubber washer" which is posted in UK Plumbers Forums on Plumbers Forums.
