View the thread, titled "Filling loop on Baxi combi boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
SQuicke
I've recently moved to a new house and noticed the pressure of the boiler was around 0.5bar. The boiler is a baxi 105 HE combi boiler. When I looked to fill it I noticed the filling loop was missing and even the 2 copper pipes which connect to the cold water in and heating return were not there. I found the filling kit online which was a baxi branded one for my boiler and attached the cold water copper pipe no problem. When I took the end cap off the heating return water sprayed out even with the valve on the pipe shut. The pipe which comes down from the boiler seems to be infront of the valve which means taking the end cap off will result in the central heating water emptying out all over the floor.
Is there any way around this problem or will I have to empty the system to put this pipe on and then refill it from empty? Hope i've been clear enough!
Welcome!
You'll have to empty it going by your description.
Thank you! It's my first house so I'll probably be around quite a bit with problems 🙂 It's all a learning curve!
I suspected as much, oh well off to b&q to find some hose then. Thanks for the quick response
Reply to the thread, titled "Filling loop on Baxi combi boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
