View the thread, titled "Finding x, (w and z) zones for fittings" which is posted in UK Plumbers Forums on UK Plumbers Forums.
pudzamoisey
First off just want to say i'm new here but so fr have been enjoying just browsing through the forum. Anyway it's suppose to be something really simple but for some reason i'm having trouble with it. How exactly do you find the x zone (or dimension) for a fitting. I was told that you just simply measure where the pipe stops inside the fitting to the edge. Though someone else is telling me that you measure the whole fitting and subtract the cut off point. I'm sure it's somthing quite simple but it's just confusing me for some reason. All help appreciated.
HI
The x dimension is used for copper, push fit, soil and waste fittings and the z dimension is used for low carbon steel.
To find the x dimension measure the fitting from the centre to the end where you insert the pipe, then insert the pipe fully to the stop and mark on the pipe where the pipe meets the fitting. measure the amount of pipe that is inside the fitting and subtract that from the measurment of the centre to the end the figure you are left with is the x dimension.
Similar way to find the z dimension apart from the fact there is no pipe stop in LCS fitings, so you use the insertion depth. For example on 15mm LSC the insertion depth is 13mm so you take that off your fitting measurment and that leaves your z dimension.
Hard to explain this without the use of drawings but i hope this helps.
HI
Thanks a lot that has helped a lot, thanks again!.
Reply to the thread, titled "Finding x, (w and z) zones for fittings" which is posted in UK Plumbers Forums on Plumbers Forums.
