doug
Hi again guys. I've been called out to a firebird enviromax floor standing boiler. 26kw
It's only three months old the manufactures don't want to know neither does the installer.
The Condense is not frozen the filters are all clean and oil freely flows at th boiler. I have bled the pump.
The boiler really tries hard tO fire but won't. any
ideas please
Has this happened only recently? Could it be the cold weather? I'm wondering if water has got into the oil line and frozen it. Not common but by no means impossible. You could try putting a really hot wet towel on the oil line before it goes into the house.
Firstly is it running on gas oil or Kerosene? These cold temperatures the last few days could have caused gas oil to start waxing.
Has it been working fine up to now?
Is it a one or two pipe system (i.e. check the Tigerloop for ice)
Is the pump pressure fluctuating as it runs?
As well as emptying the filters, did you change the paper elements as water could have got onto them and frozen?
Check if it's the supply - try running it with the flexi hose dipped into a carton of fresh fuel taken from another source.
