F
Foster777
Hi all,
just a quick question from a novice!
I started to do my first bit of pipe work on a veissman 26kw heat only boiler the other day, aswel as coreing the flu out and installing flu, with a little help from my mentor I may add.
I piped up the flow and return, which come off the top of the boiler, however my mentor said to include a unequal tee, 2 x 22mm and a 15mm so that he could put the expansion vessel on. I was so In grossed on what I was doing, and didn't ask the questions that I am now having to ask here, also I've already forgot what I did 🙂.
would the expansion vessel tee of the flow, hence taking the expansion for the heated water?
also, apart from the gas, would there be anything else coming off the boiler other than what I have already mentioned? And, where would the pump be on a heat only boiler? As when I piped up the flow, no pump was on there?
i didn't see the completed boiler install, hence why I'm asking these questions and would be greatfull for the advice given,
cheers.
cheers.
