T
typer_owner
HI All
fited a new Fluidmaster pro for the toilet due to slow refilling however i have a leak but not from what i did i think
it seems to be coming from the plastic joint just abovr the water supply tap
is there a quick fix?
call a plumber before you get a bigger leak, cheaper in the long term.
Don't think there's a shortcut here mate. Sorry to hear it's leaking. Doesn't sound like it was your fault. Just bad luck.
Maybe, isolate. Remove and change the part for new. Or call a plumber...and let them do it! Prob cost you £45 in labour, no biggy.
Welcome to plumbing. Touch it and it leaks. If I change a flush valve for a customer on anything other than a new looking toilet and they want a fixed price, that price will include replacing everything because half the time that's what you end up having to do.
I agree I usually change the washers in ball valves rather than replace to much grief otherwise. If I have to remove a cistern I change the lot close couple kit, doughnut, flush valve & syphon. Costs minimum £75 ex vat takes less than an hour good value for money. Rusty nuts usually add about £20 to the job.
