skunkandgrish
Hi All
I am fitting an oven under worktop and between to brick pillars so can't get behind the oven to plumb it in. Some one suggested you can get a flexible hose so you can slide the oven back into place.
Is this correct and where would I get one from.
To make things a little more complicated the set up is lpg. I have 10mm copper pipe going from a gas bottle through from outside and will need to get a reducer to fit the flexible hose, but I wanted to check if it is safe to have a flexible hose behind an oven and what sort of hose is safe to use.
Many thanks
Chris
Many thanks
Chris
