Hi Friends
Can you advise me please?
Going to fit a new cistern tomorrow at a house where the old has cracked and flooded.
I have purchased the new and it comes with opella siphon and fluid master inlet valve etc.
My question is about the flush pipe as it is not close coupled.
The opella siphon thread comes out of the cistern bottom and then has a back nut fitted, the flush pipe then has a rubber washer fitted on it and is then screwed to the siphon bottom by compression, I think that's all OK, there is another rubber washer in the pack that I assume gets fitted to the bottom of the flush pipe and fits into the toilet?
Is that correct? I've never fitted or even seen on of these fitted before.
Also, does anyone support the cistern with brackets or any other way (obvoulsy screw to wall)?
I am OK with the rest of toilets etc but this is new to me.
Any advice or comments appreciated.
Thanks as always.
Rocket.
Thanks as always.
Rocket.
