Dharma
Firstly, Just to say that I'm a complete novice at this so I really appreciate any help that I can get.
A few months back, our push button toilet started leaking from the back under one of the nuts. I called a plumber in and he did his thing and the leaks stopped for a few months before it started again. So this time, I thought I'd try and sort the problem out myself!
Here's the picture of the toilet from the top.
The leak happens from the left nut (see the rust)
Initially I thought it was just the donut coupling ring that was damaged, so I replaced that. But the problem continued to happen. I took the cistern off and placed it on a bucket to see where the leak was coming from. It appeared to be leaking from the metal plate and then leaking into the wing nut.
I
What was interesting was that when I replaced the donut the first time, the leak didn't occur until I flushed. But there was nothing wrong with the donut itself. Therefore, I'm guessing that when the flush mechnism is moved anyway, a leak occured. (When I sat the cistern on a bucket, it was leaking without flushing).
Here's a picture of the bottom of the cistern with the coupling nut removed:
Theplastic coupling nut was sealed with some sort of sealent.
I was wondering, what is the best way to get the leak to stop please?
Thanks in advance!
I
Thanks in advance!
