View the thread, titled "Fixing bath tap shower mixer to wall" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Matt0029
If have the below shower/bath tap mixer to fit. The finish wall won't be tiles but plastic sheeting. That isn't too strong. So I want a way of fixing the shower to the wall before it's sheeted. Do I use the offset connectors supplied and a back plate elbow or buy shower mounting kit? It's on to a solid wall, well it's a thermal block wall.
Stick two 15mm pipes out that are properly secured in the wall then use a fast fix kit? Usually do bar showers like this with plastic paneling and don't have any issues, can't see a bath/shower mixer being much different?
That's what I wanted to do but the shower bath mixer is heavy. I'd worry that it may pierce the plastic. That is hollow on the inside.
Reply to the thread, titled "Fixing bath tap shower mixer to wall" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
