Flat plate close coupled kit
View the thread, titled "Flat plate close coupled kit" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Matt0029
Has anyone done a toilet repair on a toilet that has a flat plate closed coupled kit. So there are indentations on the toilet cistern for the bolts to sit no in the metal close couple kit. I did one the flate plate and donut was almost rusted . Just put a normal close coupled kit I it but it leaked. Anyone had this before?
Ok, now it depends on the seat of the pan where the cistern rests and the flush pipe goes as to which CC washer you would use. Now, some CC pans have a circular indentation around the hole the flush pipe goes into, on these you should use the circular doughnut rubber washer. Now on some CC pans there isn't that indentation so you should use a cone shaped rubber 'doughnut' or a foam normal circular one.
If you disturbed the flush valve while replacing the CC kit you'll need to replace the rubber washer and clean off any sealant that some idiot may have put on. Top tip, NEVER use white sanitary sealant on the rubber washers or seals, it not only corrodes them over time, but can deform the washer when tightened and also makes things difficult when they need to be replaced. Plumbers mate is the way to go.
That should do the job.
I'm sure others will have their method of doing things as well. The more different ways you can learn to do a job or method the better.
Previously it had a kit like this
Reply to the thread, titled "Flat plate close coupled kit" which is posted in UK Plumbers Forums on Plumbers Forums.
Matt0029,
Matt0029,
