M
MartynJM
Hi Everybody, new to forum with probably a daft question but I simply cannot get my head around this. We are building an extension and currently putting in the flow & return pipes for the central heating. My question is: can the 22mm flow and return pipe upstairs be split with a 'T' to go to the front and rear of the property or do they have to be a continuous run of pipe? my thinking is that the return on both sides of the 'T' may be of unequal flow rate therefore one side of the 'T' reducing the return flow of the other? I have added a quick drawing of the layout, I have not shown all branches and rads but the number of radiators on each side of the 'T' is noted. The 6 rads to the rear of the property include feeds to 3 downstairs rads. There is also a 'T' splitting the downstairs and upstairs before flowing and returning from/to the boiler which is standard practice but is it standard to split the pipe on the upstairs run?. I am fairly sure 😕 this layout will work but will it be efficient?
Thanks in advance for any help to set my mind at rest.
