Realistically, does this scenario happen often? How many times has someone came across a situation where by the regs it was wrong, but right by the manufacturers instructions?
Surely manufacturers are required to produce their appliances so they fully comply with our regs and not just used as a guide?
I would say though that regarding the flue in this thread. The "standard" would be to clip at every change of direction and just before if leaves the roof. But if the manufacturers produced their flue so that when pieced together it was rigid, and they stated only 1 clip at the exit was needed, then this would be acceptable.
So basically what you are saying is that regs say 1.8m but if MIs state every meter or change of directions this can be ignored and 1.8m can be used?
Regs say 1.8m and at every turn of direction but I think we’re going a bit over the top about it. 1m would be fine because 1.8m is a maximum.
So if MIs said every 1.2m you would ignore and use regs?
No. You have to follow MIs, but they cannot over rule Regs. They can obviously demand higher specs, and of course you can work to higher standards.
But my point is that MIs are not superior to Regs, which is what folk keep saying.
so lets say
clipping distance
regs every 2m
mi every 1m
you would go off the regs then
quite a bit regs want flues screwed every joint for viessmann this is a big nono as it states in the mi do not screw the flue as with expansion the flues split
The flue runs up from the boiler into the attic. There are then two 45 degree elbows before the flue runs out to the rroof.The flue runs parallel from the boiler to the bit going out of the roof with an angled bit in-between. Where by regs should the brackets go and how many will be needed?
I would always put a clip at each join horizontal or vertical, deffo 3 for this one.
Weird, I have had our last boiler and loft flue fitted about 7 year ago. British Gas always check out our loft to check flue. This year I had safety note issued
(WRITTEN AND NOT VERBAL) that issue with flue supports. Not even given a quote by gas engineer who fixed our pilot light for hot water on hot air and hot water combination boiler. Forgot to mention 3rd engineer since I had out yearly boiler service January. Been without gas hot water since he left. Had 3 engineers since unsuccessful in fixing pilot light. Now May and young lad fixed. Something to do with pump. First time ever my flue been mentioned. Only noticed whilst checking paper work
