View the thread, titled "Flue integrity test" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Scott_D
Subscribed
I always do a flue integrity check on the air inlet sample point. Never had an issue.
Doing one today and I realised I don’t know what values the are to be classed as a fail.
Can’t seem to find it in my books either.
Is there a TB I can read to refresh my brain?
Its air intake so the the same as fresh air, anything above normal co levels would indicate a leak from the flue seals into the air intake. This would also result in higher than normal flue readings
Edit quick google search brings up 0-9ppm for normal indoor co levels
Reply to the thread, titled "Flue integrity test" which is posted in UK Plumbers Forums on Plumbers Forums.
