steads
Please help I have a floor mounted ideal boiler , flue liner goes up through a flue out via a hood /cowl , for the past 3 months this wet oily sludge has been working its way down the flue collecting in the bottom and when the heat from the flue warms it up it seeps down the inside and outside of the flue pipe in the kitchen making hell of a mess on the boiler and round the floor and walls , i have checked the chimney stack to see if water could be getting in nothing visible or obvious, i have checked tanks in loft bone dry and tank in airing cupboard bone dry, to try and stop the oily sludge leaking into the kitchen i have applied fire cement round the collar that buts up to the base of the flue, and i have cleaned out the base of the flue / chimney best i can, the flue liner goes through a hole in the concrete slab at the base then sits into the collar on the top of the pipe in the kitchen, where the flue pipe goes through the hole in the concrete slab there i a half inch gap all the way round the flue pipe this is where the sludge sits then seeps through when warmed up , what i want to know is there any sort of heat proof liquid sealer that i can pour into the gap that hardens when cured and keeps the moisture out , i really don`t want to replace boiler and get rid of stack as money won`t allow at this point in time, any advice would be most appreciated 😕😕😕😕😕😕
