R
rongagain
My daughter's flat is on the 4th floor and she is in need of a new combi boiler. The flue exits through the wall.
My questions are, can the boiler flue be installed from inside the flat as it is about 40ft up from the outside.
Also does the position of the flue as it exits the boiler change from make to make. She currently has a Myson Midas Si.
Thank you very much for any help/advice. Anything else she needs to consider?
btw she has been quoted £1350 + vat for an ideal 30 boiler fitted IF the flue can be done from inside or 1799 = vat if flue needs outside work, the extra is for a 'cherry picker'. What do you think?
