personally I'd AR as it could move whether or not it is in a void without the correct support
+1 ar defo
ncs would be no access to flue in boxing eg no hatches
Eh no access to flue in void would be AR as per the regs
[DLMURL]https://engineers.User PlumbersForums.net Instead - Copy the content, don't link to it.co.uk/doc/FluesInVoids/TB%20008Ed%203%20-%20Existing%20concealed%20room-sealed%20fanned-draught%20boiler%20chimney%20-%20flue%20systems%20-%201%20April%202013.pdf[/DLMURL]
Yeah AR if no hatches. I just found it strange that because it was in a void it made it AR, but if it wasn't only NCS. To be honest there is less chance of flue being knocked whilst it's in a void, as the joints were screwed and was completely rigid, there's very little chance of it coming apart or being damaged by 3rd party.
The thought behind it being if the flue failed in a void you would be less likely to realise thus causing more risk to life.
Ar, ncs. Doesn't matter. No one seems to take any notice.
"The last bloke didn't say anything". " it's been like that for years"
Absolute rubbish!!Came across a flue in void, inspection hatches fitted to standard, flue was solid and rigid, joints screwed, but no supports. Boss who was with me seems to think this is AR as its in a void but only NCS if it wasn't in a void. Is he right?
1.8m what the freck ?
+1 alt-least one clip per m length
its why they supply a clip with each 1m extn
yes sometimes you need two clips per length
A flue must be supported every 1.8 meters or it's AR.
Correctthats maximum every m should be or every joint
Reply to the thread, titled "Flue supports in void" which is posted in UK Plumbers Forums on Plumbers Forums.
