View the thread, titled "flush pipe" which is posted in UK Plumbers Forums on UK Plumbers Forums.
dave1
i need to fit a high level 3 piece flush pipe, just wondering how do you connect the three pieces together, do you use solvent cement or something similar or do you just fit it dry many thanks.
Dave use solvent cement, but i would suggest making up first and then mark pencil lines on each section of pipe so when you dismantle to glue you push them back together with the pencil lines in line as once glued you wont get apart again.
Migo, ive never seen or used push fit type (must be something new)
Reply to the thread, titled "flush pipe" which is posted in UK Plumbers Forums on Plumbers Forums.
