G
glennybee
Hi folks,
I've been having problems recently with my hot water, sometimes its hot, mostly its not lol. It still flows out the tap at the same rate but it's not warm in the slightest. I'm covered with BG Homecare so called them out and the engineer said there was a build up of sludge in the pipes, he used a magnet thing to determine this. He also said it will cost me around £600 to flush the system out and clear the sludge. Surely if there was a build up of sludge then the flow would be affected and not the temperature of the water? I was initially thinking the thermostat on the boiler but I wasn't home when he called and you know what wifes are like trying to remember technical stuff.
If it's simply a case of flushing out the system, I'm sure I could do that myself without using any power flushing equipment. Would it be a case of closing off the water, opening the drain outside and letting it empty, open mains water supply again and let it flush around for a while, leaving the drain open?
I don't have a combi boiler, it's a gravity fed hot water system, if this makes any difference.
Thanks for any help, its greatly appreciated and hopefully will save be a few bucks. 🙂
Glen
Glen
