M
Minty_Cymru
Hello all.
The plumping in my house is about 23 - 30 years old - looks like it was performed by the cheapest bidder. I've lived there for about 14 years and for about the last 2 years the ball valve in the cold water tank (in the attic) has 'dribbled' constantly - which obviously sent it out the overflow.
I managed to get the time to replace the ball valve this year and fitted one just the same as the one that was removed, your average normal everyday valve looked like this:
When I was fitting it I moved the tank slightly (literally by about an inch or two) this may (or may not) be significant.
Later, when refilling the tank, when the valve was near to closing I had a very aggressive vibration from the cold water pipes - I found that the piston inside the new ball valve (which was attached to the vlave washer) was vibrating inside the valve. I had no choice but to refit the old valve until I could find a solution.
I then bought a new ball valve from Focus DIY - a slightly different valve in appearence, just like this:
[DLMURL="http://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=9270919&fh_location=//catalog01/en_GB/categories<{9372015}/categories<{9372046}/categories<{9372180}/specificationsProductType=toilet_fittings/specificationsSpecificProductType=valves&tmcampid=4&tmad=c&ecamp=cse_go&CAWELAID=266881092"]Ball Valve High Pressure 16131201 1/2inch Part 2, 16131201[/DLMURL]
This seemd to cure the problem, until now (about 5 months later). Starting this weekend I've had 'Fog Horn' issues from the cold water system connected to the header tank. This happens when the valve is beginning to close and will remain until the valve is fully closed. For some reason there is a very long period of time between closing and fully closed (up to an hour) when you can hear the flow slowing down, going through 'dribble' and eventaully will drip for a while.
During this time I get the 'Fog Horn' in 'waves'.
My initial reaction would be to fit a new ball valve, but since this one is only 5 months old I'm a little sceptical that this is the issue.
If I could get the valve to react quicker (and not spend so much time in the 'closing' position) I'm sure this would cure it.
Any thoughts? I would appreciate any help I can get.
