View the thread, titled "Freestanding bath fitting" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
I have a freestanding bath with claw feet, the overflow, shallow waste and outlet are all exposed and chrome. The pipework will then go under the floor which will be tiled and finished before the bath is fitted. How do I connect the chrome pipework that is above the floor to the pipework that is under the floor. Thanks in advance. Roy
You will need to bob on with your first fix in regards to height build up
As for taps depends on the manufacturer you want one with a baseplate that the tap connectors too most come with just a flex and compression joint that has to be made off before tiling
Reply to the thread, titled "Freestanding bath fitting" which is posted in DIY Plumbing Advice on Electricians Forums.
