View the thread, titled "freezer water filter" which is posted in Bathroom Advice on UK Plumbers Forums.
plumbinguser
Hi
I have a fridge/freezer which has an ice cube maker on it. The water filter is supposed to be changed every 6 months according to the manual but I would like some advise on this
1) Is 6 months too soon for a water filter, how long can it go whilst still being effective.
2) The filter is external (seems like an after thought by Daewoo) and has simply been fitted on the floor behind the fridge freezer. This means to change it the fridge freezer has to be pulled out, filter changed and then pushed back in. This seems a bit of a to do really.
What I would like to do is have the incoming water pipe extended up near the height of the fridge and then to route the plastic tube from the water pipe to the filter. This filter I would like above the fridge (as there is a top over the fridge) in its own mount and then the filter output tube to go all the way back down to the bottom of the fridge. This way the change becomes simple without having to move the fridge freezer.
The above long winded but am I able to do the above without it affecting the action of the filter (as currently all below fridge at floor level) or has it been fitted at floor level for some reason?
Please help...
Colin
hi mate, absolutly no reason whatsoever why you can not re site the filter, i fitted one last week, placed the filter just above top of fridge, easy access and out of site, actually if u read the fitting instructions u will find that this is preferrable.
Thanks for the replies,
I will get someone out to do the mods and change the filter at the same time (I presume I am ok to overrun on the filter for a few weeks or so!)
Hi Tom
Not sure where to get them from yet, I presumed they were generic (as external) and would be similar to the units we have on water coolers at work.
Will check in the manual later.
Reply to the thread, titled "freezer water filter" which is posted in Bathroom Advice on Plumbers Forums.
