View the thread, titled "from water leak to low then high pressure" which is posted in Bathroom Advice on UK Plumbers Forums.
Q
qwintik
Worcester greenstar heatslave 18/25 internal oil boiler.
Last week the pressure dropped very low over a few days, took door off, shone torch inside and big drip drip drip on water pipe, so I let it go cold and nipped up the nut. Good no more leak.
But pressure rose quickly to 3 bar and I investigated the next day when boiler was cold but pressure down to almost zero.
I pressed the nipple on the pressure vessel and a tiny spit of water came, I checked the vessel's pressure which was zero.
Ordered a new pressure vessel and pvr and they came today, sadly the wrong pvr.
Anyway as I did not think pvr had actually blown I fitted the pressure vessel and filled the system up to 1.3 bar, switched the boiler on only to see the guage slowly rise to almost 3 bar when I switched it all off.
Please tell me what I probably did wrong!
Didn't call an oftec registered engineer
decided plumbings easy
misdiagnosed problem
used the wrong remedy
Likely Ordered parts which were not needed
Pretty sure no ones going to give you a solution because clearly you like having a play with a boiler yourself!
get an oftec registered engineer to repair it and give it a proper service 🙂
You made a common mistake, you didn't ring an engineer, - probably simply to save money or perhaps you have had bad experience with a previous engineer, or maybe both.
We all have done it before - decided we can do some other trades work, bought parts, tools & wasted time & discovered we didn't know enough when it was too late.
Put it down to experience & get a decent engineer to sort it. Sometimes an engineer can diagnose & fix several things wrong on a boiler for only a few pounds, which is less than you may have wasted already.
Post a new thread here......
[DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
Reply to the thread, titled "from water leak to low then high pressure" which is posted in Bathroom Advice on Plumbers Forums.
