View the thread, titled "G1240 Riser pipes small hole" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Where can i buy a replacement Harvey G1240 Riser pipe for my Harvey water softener
It has a small hole right on the bend is there is a fine mist of water coming out
seen them at £70 a pair
Already replaced it about 3 years ago with a Modified one with more plastic support on the bend
I heated up the area with soldering iron to melt the plastic over the hole
Can they be got single instead of a pair
Reply to the thread, titled "G1240 Riser pipes small hole" which is posted in DIY Plumbing Advice on Electricians Forums.
