gas capping
View the thread, titled "gas capping" which is posted in Gas Engineers Forum on UK Plumbers Forums.
G
gaspastemania
Just curious as to who caps the gas where when doing any work on the gas line , personally i cap the gas immediately after the ECV remove the anaconda and cap it at source. I notice others jus place a blanking disc in and others disconnect meter and cap .
fit cont. bond, loosen meter tails, remove outlet side, swing meter out fit blank cap an retighten both ends, technically the correct way is to remove the meter to a safe place and fit dust caps, cap the supply and fit those internal red caps into the meter tail nuts, however i asked a CORGI inspector years ago did he want me to remove completely or swing it out as i normally do, he said technically you shouldnt support the meter on one side only in case it pulls the bracket off the wall, to which i answered i would check how secure the bracket was first and if loose i would fix it properly, he said 10/10 for answer get on with it
i agree,i use a car jump lead as my temp earth link better clamps and thicker cable
Cap the gas meter!!!!!!!!!!!!! huh eh what AH I know what yer mean, yeah I just leave me stetson on the meter, I aint gotta cap!!!
If you leave the meter in place, it could theoretically be damaged this way.
you can always be sure the last meter of the day is a quantum meter and no matter how hard you try you trip the blumin thing..... always on a friday tooo.......
Reply to the thread, titled "gas capping" which is posted in Gas Engineers Forum on Plumbers Forums.
gaspastemania,
bengasman,
