spanners1967
I failed my Level 3 gas assessments on gas controls. Working as a new installer I have been told that this can be a common pit fall for first assessment candidates. I am resitting on 6 August .Anyway, I will put some of the questions I had up here , with some answers i think are right and would appreciate any comments or feedback... thanks in advance
1 Liquid expansion FSD- what is likely fault if gas flame remains on low?........
FSD faulty?
2 Liquid expansion thermostat- what is likely fault if gas flame remains on high when required temp is reached?..... Phial not located correctly
3 Multifunction valve- what's most imporatant safety function of these? .... The FSD?
4 likely fault when cooker tap is turned to simmer and burner goes out? ..... small drilled hole in gas tap blocked
5 Thermo electric valve- likely fault if thermo electric valve does not close withgin 90 seconds?... valve jammed?
6 electro thermo - likely result of thermostat phial/probe not correctly positioned ? burner remains on high?
I have most of the other fairly sussed but would greatly appreciate any comments.
:nopity:
FSD faulty?
:nopity:
