Hi all,
how much do you normally charge to install rigid piping from bayonet fitting to hob?
The hob is already installed in place
Also, where should the isolation valve be located as I'm sure it probably needs to be somewhere easily accessible behind the base unit doors and not be behind the oven?
What kind of connection is attached to the hob? is it just a Simple solder job to 15mm pipe? (I've not installed a hob yet) [emoji5]
Anyone else get text messages from customers at 11.20pm on a Saturday night asking for a quote to work in Sunday? [emoji35]
