Gas hob isolation valve behind a gas cooker
View the thread, titled "Gas hob isolation valve behind a gas cooker" which is posted in Gas Engineers Forum on UK Plumbers Forums.
what are the regulations ? obviously the hob has to have a rigid connection and a means of isolation but is ok for the gas cock to be hidden behind the electric oven or does it have to be accesible ? say in a cupboard next door etc .
THE TITLE WAS MEANT TO SAY ELECTRIC COOKER SORRY!
not sure what the regs state but i work on it should be accessible otherwise whats the point.i mean its not good really if its behind an electric oven and you have to undo 4 screws , just to get to it.
i appreciate the chances are if your replacing the hob you're more then likely going to move the oven anyway.
Its better practise to put it in the cupboard next door, but gas safe guy i asked said it was fine behind a oven.
not a problem with gas tap behind ,elecy oven ,as the elecy oven is,nt classed a permanantly fixed ie gas tas accessable
agree with redsaw dont see the big deal if there was an emergency the ECV would be the obvious choice
only people who operate that valve are us when working on appliance
was told by an inspector that it can be behind the oven as it is for servicing rather than to be used by the homeowner. As said the ecv is for the homeowner to use in an emergency
its a service valve not an emergency valve,
My customers cant use thermostats nevermind Iso valves
no problem with gas isolation valve behind a electric cooker also make sure hob is fitted with 3 amp fuse
Reply to the thread, titled "Gas hob isolation valve behind a gas cooker" which is posted in Gas Engineers Forum on Plumbers Forums.
piperdave,
gas57,
