Gas Meter Bracket - Help! Arguing with First Utility
View the thread, titled "Gas Meter Bracket - Help! Arguing with First Utility" which is posted in Gas Engineers Forum on UK Plumbers Forums.
At the end of the day and regardless of 'whose bracket' this is,
if the company replacing the Meter have an issue with ownership, cost and responsibility, then on first inspection of that and prior to commencing work they should, in my opinion, make the responsible person aware that the Meter requires an adequate support and either the responsible person needs to have it seen to prior to the Meter being changed or they can do it for an extra charge during the Meter change.
I think that would demonstrate common sense and fairness.
I agree, Last Plumber. Seems like the installer just decided to get in and out as quick as possible. I find it amazing that they actually re-used that bracket, whoever it actually belongs to.
I think you'll find if the pipe work to the meter is securely fixed and is of rigid pipe work ( copper etc ) it doesn't even need a fixing bracket. That's copper on one side.
But on the regulator side there's going to be a semi rigid anaconda, if you knock the meter without it being secured to a bracket wouldn't that place strain on the copper pipework possibly leading to a leak?
I'm not saying it's a good thing, that's just the regs if it's and old installation. So the energy company can always get out of doing it. I did one recently where the meter and bracket were replaced but the bracket screws came away from the wall. I removed the meter and refitted the bracket correctly. The energy supplier paid the client who then paid me.
This is what happens when you dont have to inform ncs to the customer.
If you want them to come back to fit a bracket, ring them and demend they remove THEIR meter from YOUR property, inform them you have purchased your own gas meter and will be having your own meter installed.
Reply to the thread, titled "Gas Meter Bracket - Help! Arguing with First Utility" which is posted in Gas Engineers Forum on Plumbers Forums.
Deleted member 102506,
Bibbs118,
