View the thread, titled "Gas Meter outlet not sleeved" which is posted in Gas Engineers Forum on UK Plumbers Forums.
sansks
Hi all,
I did gas check and found gas meter istallation as follows.
Type:
Outside meter box
Surface mounted meter box
Pipe work: outlet pipe work go through brick wall not sleeved/sealed. the entry of the pipe work (outlet) within the meter box.
Inside the house, the pipe work goes under the concret floor.
Is this NCS or AR?
Please correct me
According to BS the outlet pipe work should come out the meter box then enter the property. (AR)
Also pipe work should be sleeved and sealed.(NCR)
Should I fail the test
Sansks
Shanks any gas related questions must be done in the private gas safe section so prevent DIY work , please increase your post count and apply thanks
Reply to the thread, titled "Gas Meter outlet not sleeved" which is posted in Gas Engineers Forum on Electricians Forums.
