Feb 16, 2020
DIY or Homeowner
Hi
I recently moved back to Europe from the Middle East and shipped my belongings. In that shipment was a Bosch gas cooker/oven. When in the Middle East it was using gas cylinders as there was no mains gas. Now I am back in Europe I would like to use it if possible, however the sticker on the back of the oven states it is setup for 28-30mbar, the regulator also states 30mbar.
I can only get 37mbar regulator to fit the cylinders in Europe. So my question is would it be ok to use a 37mbar with this oven?
According to the oven manual the jets are the same for both 30-37mbar, so I am unsure if there is something else I would need to get changed or adjusted.
I have attached some photos of all the information I have that I hope will be of help.
Thanks in advance.
Best ring the manufacturers tech helpline to be sure it is going to be safe to use with that regulator.
