hammers4spanner
Subscribed
Mar 21, 2012
7,703
3,197
113
Got a call out to this right at end of the day ,
gas powered water heater hot water supply pressure to taps has dropped off , its a tank fed water heater with open vent and pumped circulation . I can hear the air going through pump and spluttering through pipes to taps .When i run taps on one side of class the pressure is fine goto other side and its a bit of an issue al in all its 7 hot water draw offs either side of class so in total 14 taps . i know the pressure was fine prior as have done the odd leak here there in class .
Thinking to try draw air lock out through pump or would wet vac be man enough???
Any other suggestions welcome
