View the thread, titled "gate valves" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I do, its a lot easyer than changing when the pipe is full 😉🙂😀
drain down is better ,as gate vavles tend to seize , but perfer using bung,s , in quick repairs .
Its okay draining down sometimes.
But get a job on a cylinder cold feed and you can trap an awful lot of air in it if you drain down.
At least if you open a gate valve with a full tank of water, the surge of water usually drives the air out.
Reply to the thread, titled "gate valves" which is posted in UK Plumbers Forums on Electricians Forums.
