I have a Geberit concealed cistern for low height furniture. This has a dual pneumatic flush, and has worked without any problems for a few years. Recently I found that when I push the full flush button, the toilet flushes OK but the button doesn't return fully (i.e. it stays pushed in slightly). The amount by which the button stays depressed increases with each flush so that after a couple more flushes the button stays half in and, if I then try to do a full flush, it only half flushes (and the button stays half in afterwards). If I disconnect the full flush pipe briefly from the back of the push button unit, the button immediately returns to the proper position, and I am back to where I started. I don't want to buy a new push button unit if the problem is the flush control unit and vice versa. Any suggestions appreciated. The half flush (which gets used more than the full flush) works fine.
