C
camfish
Any advice appreciated got a job.with runs of 3 toilets connecting into vertical stack. When the 1st toilet is flushed a small amount of dirty water enters the last toilet, checked the falls and a bit of backfall and the cast bend to the cast stack is more like a tee. No blockages as all been jetted, I'm going to jack up the horizontal section to the stack and change the connection to stack to a swept bend, I'm doing this on all 6 floors, my concerns are getting a fall on the 3 toilets as obviously the outlets are all the same level so I'm thinking of using different pan connectors as I said any advice re this appreciated. Also bit worried about the stack dropping when the tees are removed as a lot weight above even though all bolted up
